4
This discussion topic has been answered Discussion topic: Sky Glass TV won’t turn on
This message was authored by: Han4444
The red light is on at the front but that's the only response to the remote. The TV won't respond to voice command, the remote for anything else , the button on the RHS and motion any more. Changed the batteries and restarted wifi.
This message was authored by: MarkGoldsmith Answer
Re: Sky Glass TV won’t turn on
Have you tried unplugging the TV for a couple of minutes and seeing if that helps?
Avatar for Han4444
And that has done the job! Thank you - completely forgot the first rule of tech stuff: turn it off and on again 😂
No problem - it's quite common for little bugs to occur on Sky glass and Sky stream where a simple unplug for a couple of minutes resolves it.
This message was authored by: Bryevans
I have the same issue and have to do the unplug every day
