4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by Freya14 This message was authored by: Freya14
Nor turning on
My sky glass TV has been stuck flashing red and not turning on at all. I don't understand what issue is in my area because my Wi-Fi is working absolutely fine. If there's maintenance being done we should be notified as I'm quite annoyed.
This message was authored by GiantsFan69 This message was authored by: GiantsFan69
Re: Sky Puck & Sky Glass Power up issues 19-9-24
re booted my glass but of course after completing some updates it just went dead again. Little concerned this may have made it worse if /when it ever works again !
This message was authored by Mr+Gray This message was authored by: Mr+Gray
My sky glass TV would not come on .now it as but I can't get it to correct to my WiFi it keeps sayin
My sky glass TV would not come on .now it as but I can't get it to correct to my WiFi it keeps saying could not connect
This message was authored by CathSteen This message was authored by: CathSteen
Re: Sky Glass Power up Issues 19-9-24
I was holding it for at least 5 minutes and no lights whatsoever so clearly reset process working for some but not others. This is where an update from sky would help
This message was authored by JPCQ This message was authored by: JPCQ
Seeing as people seemed to be able to get the reset working I tried this morning - great news....it's switched on, updated and linked itself to the remote.....not so great news....please use sky.com/activate and type the number on the screen in - shockingly I got an error message so phoned the number they told me and the machine that answered couldn't figure out what I was saying so gave up and will try again later when I get a break in work. Absolute joke 😤
This message was authored by Debbie95 This message was authored by: Debbie95
Haven't got past anything lop
This message was authored by Davidr+542 This message was authored by: Davidr+542
Re: Sky glass tv won’t turn on just flashing red light
This worked ! You're an absolute gent and a scholar,  thank you
This message was authored by anthony+david This message was authored by: anthony+david
Re: Sky glass tv won’t turn on and no red light comes on
Experiencing the same problem.  Sky Glass dead   Had issues with the puck not working yesteday. Gave up after others reporting the same.
This message was authored by johnjpauljohnpaul This message was authored by: johnjpauljohnpaul
every time I turn it on I get white light flashing and the it eventually goes to the "Check Device Power" screen. with two button options ""Connection Guilde" (hilighted in white) and "source"
Should I do anything or should I wait?
This message was authored by TBE This message was authored by: TBE
So im in area just outside of swindon, where are you guys?
This message was authored by Gabbi This message was authored by: Gabbi
Is everyone still having the same issue today? My glass would not turn on at all yesterday just standby light flashing on and off. I've tried all the solutions on skys guides but non work. Same again today it will not come on. I have been trying to call them a couple of times and after waiting for forever on hold it then says about there being no available agents and it cuts me off 😤
This message was authored by RS071 This message was authored by: RS071
Sky Stream refuses to function
The puck box coloured lights come on for about 20 seconds and then no lights remain on, so my TV has no Sky.  How should this fault be corrrected?  Or is there a prblem at Sky itself?
This message was authored by NeilSh This message was authored by: NeilSh
Yes having same issue I tried the reset yesterday it did update and the. Turned of and won't turn back on again this is so annoying
This message was authored by FootPH1 This message was authored by: FootPH1
@GD1 wrote:
Thread title created to reflect current issue
I've got the TV working following tge restart process this morning. But the remote doesn't work and won't reconnect. Annoyingly, I can't even use the old Sky Q remote with it, which has worked in the past.
Re: Sky stream won’t turn on - flashing white light then nada.
Same as me
Locked
