3896
Discussion topic: Sky Glass Power up Issues 19-9-24
This message was authored by Kdoodle This message was authored by: Kdoodle
Re: Sky Glass Power up Issues 19-9-24
Thanks Peter...didn't work
Not working....still
This message was authored by Jenniferten21 This message was authored by: Jenniferten21
This is soo g the same thing to me 😞 giving error message 😭
You're now connected...set up remote and then activation code and not able to input ...fabulous!
This message was authored by Chloe240 This message was authored by: Chloe240
@lettice left it unplugged longer, still bringing me back to the pin page
This message was authored by Gemma411 This message was authored by: Gemma411
Re: No tv
I have tried this and still no joy u fortunately
This message was authored by ClaireLouise This message was authored by: ClaireLouise
Re: Can't get past "incorrect pin" on setting up sky stream
I am also having the same issues. I can not go pass Incorrect Pin.
I have done reset pin, my last four digits of my number, debit card and so on and nothing
This message was authored by Essoblue This message was authored by: Essoblue
Re: Streaming has been down for 4 days spent over 4hrs on the phone keep getting disconnected
The sky app says my service is working again but the reset still doesn't work and the screen is still dead. The pucks work ok. I've been on hold to sky for over two hours and no luck speaking to anyone so don't know what to do
This message was authored by Mark1707 This message was authored by: Mark1707
All green saying fixed but still sitting on updating software then fails goes back to reboot gone through process again still not working!
This message was authored by lettice This message was authored by: lettice
When you see the pin page, ignore  that page ( do not enter pin)  and then do a restart of the puck.
It should then bypass it the next time.
Try it a few times if so.
Sky Community Superuser. What is a Superuser? Click here to find out
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
This message was authored by Karl73uk This message was authored by: Karl73uk
Re: Is there any update on outage today we’ve had no internet or tv for days
I had no sky services for 3 days!!! YES no TV for 3 days and SKY have disgusted me with just £5 compensation off my next bill,shame on you SKY!!
This message was authored by side+kick This message was authored by: side+kick
Did you turn off by the power then press reset button keep pressing reset  whilst you switch the power back on?
Got to the pin stage once ...and didn't k ow about 'that' can't progress to the stage at the mo....
Re: No tv
This worked for me?
Re: Sky Stream Puck stuck on PIN reset
Hey 👋
I already had my sky stream puck set up when I first got it and now I'm having issues.
I can not get pass Incorrect PIN!
I have reset my pin 20times and it's still saying incorrect pin
