4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by James+armer This message was authored by: James+armer
Re: Sky Glass Power up Issues 19-9-24
I can't even get onto the site to activate it. I'm logged into sky type the website in and it comes up with a message saying ' oops there has been a problem' it's been like this for a good few hours now. I've tried multiple times on different devices and different web browsers.
This message was authored by Hobbayne64 This message was authored by: Hobbayne64
Sky Puck in bedroom
I am trying to connect it to my wifi but. pushing the button on the router doesn't work. And when I tried to enter my password my router is not on the list of available networks Is this a problem with my sky puck or my router? Other things are connected to my wifi ipad etc.
This message was authored by BobbyGooner This message was authored by: BobbyGooner
Thanks for the solution ! It worked on my Nans Puck. Took 5 mins if that. Verified the Pin with the account no issues. Didnt even have to call Sky... you saved me alot of time having to call them up :))
This message was authored by Cjooconnor This message was authored by: Cjooconnor
Same issue, I have reset and it's on blue screen with activation code but the sky.com/activate pages just keeps loading Oops theres a problem cannot load page ring sky rep for help
This message was authored by Kirsten741 This message was authored by: Kirsten741
@Cjooconnor
type the https bit in this worked for me make sure your copying the whole link into your browser
This message was authored by VeryMiffed This message was authored by: VeryMiffed
Good afternoon. I have just been poking about with this somewhat useless peace of junk. Fo far I have gotten through to the software update and have managed to reset my remote (Press 1&3) directed to go to Sky. com/activate with a code, but the "page" does not work!
That's the exact same problem I'm having
This message was authored by Fothergill1 This message was authored by: Fothergill1
Re: Hello my sky to obtained via a puck has not worked since yesterday evening . Am I alone with thi
@Heidi1174 did you try the solution as per post 2 of this thread.  You need to follow the link and then select Glass or Stream. If you follow the procedure exactly as described it should resolve the issue for you.
If it asks you to enter a PIN Sky advise that you just ignore it and switch the puck off at the wall socket.  Turn it back on again and allow the puck top reboot.
The whole thing took me about 5 -6 minutes and has worked perfectly since then.
Good luck 🤞
If my post has solved your issue please mark as an "Answer"
This message was authored by horace This message was authored by: horace
If, as I suspect, the issues we are having are due to a failed firmware update, I do wonder if simply waiting for Sky to fix things at their end might be a vain hope.
If the affected devices won't even boot up, how are they going to download and apply new firmware?
I could be wrong, of course, but my suspicion is that a successful reset at the user end will be necessary one way or another.
@James+armer Sign out of your MySky account and then sign back in again and then enter the activation code.
I can't get my puck in the bedroom to connect to my router. I managed to get the sky glass working. with the hard reset. But my router on the puck connection is not even on the list of available networks.. Pushing the button on the router doesn't work either.
This message was authored by josephbrevcat123 This message was authored by: josephbrevcat123
Sky Glass. Wont even go to standby mode.
Nothing working at all on sky glass tv. Wall switch on. No standby light. Buttons get no response. Batteries working
This message was authored by mikealanr This message was authored by: mikealanr
Re: Sky Glass. Wont even go to standby mode.
@josephbrevcat123
Known issue. See this thread: Answered: Sky Glass Power up Issues 19-9-24 | Sky Community
You need to follow the steps here:Fix your Sky Glass or Sky Stream | Sky Help | Sky.com | Sky Help | Sky.com
MikeAlanR
65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Former Sky Q, Sky+ HD and Sky+ customer.
This message was authored by KMH7 This message was authored by: KMH7
Been doing this since 1am on & off & still no joy.
I've logged out and logged back in and still continues to come up with that message
Locked
