4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by bluem00n1957 This message was authored by: bluem00n1957
sky stream now working
Try the recovery process
  1. Switch off your TV at the mains. There's no need to unplug it.
  2. Press and hold the Standby button on the right-hand side of the TV.
3. Keeping your finger on the button, switch the power back on at the mains and wait until you see the LED lights flash (this could take 20 seconds before the LED starts flashing), then remove your finger.
4. Let the Sky Glass TV complete the recovery process. This can take up to 15 minutes, depending on your broadband speed.
This message was authored by James+armer This message was authored by: James+armer
Re: Sky Glass Power up Issues 19-9-24
This message was authored by MarcelMu This message was authored by: MarcelMu
Red led is still flashing after trying the hard restart. Is this supposed to work for everyone?
This message was authored by LiamFletcher This message was authored by: LiamFletcher
Still not working, runs through some kind of update shows Sky logo a couple of times then red light flashes. I press 7&9 together then continue but it won't connect to router.
I've tried this multiple times and still getting the same error message
This message was authored by Mallymaz This message was authored by: Mallymaz
My Ky
When will my Sky Glass be up and running??
And why wasn't I notified (had to get info from X)
If been spending most of the morning trying to fix it! 🙄
This message was authored by Kirsten741 This message was authored by: Kirsten741
MY RED LIGHT ISNT EVEN COMING ON , just the microphone sign lighting up , tried the answer in the post
This message was authored by mikealanr This message was authored by: mikealanr
@Maggiemc7
A reboot won't work you have to follow the recovery procedure as outlined by Sky on their service checker.
https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on
MikeAlanR
55" Gen 2 Sky Glass atlantic blue, 65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Former Sky Q, Sky+ HD and Sky+ customer.
GD1
Re: My sky glass tv isn’t working properly
@Alan155   I have merged your post to this existing thread that is discussing the current issue, the thread you tagged on the end of is unrelated to this issue.  There is no 2nd line support number.
Please try the steps in the post marked as answer
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
This message was authored by Ingilybob This message was authored by: Ingilybob
  • @Kirsten741 same here, no red light since this morning when I first tried to turn the TV on. Only the mic light is on, tried resetting via the "given answer" on here but no luck. I guess it's just a waiting game at this point.
This message was authored by lettice This message was authored by: lettice
@Mel112 wrote:
Is everyone still having problems with their stream pucks. I've followed the steps to reset it which worked. Linked sky account worked but then tried to pop pin in and now blocked me from signing due to wrong pin (which it wasnt). I've been off since early last afternoon and still no luck
As mentioned in post 2 answer.
If you have a problem with entering pin.
Power off the puck or Sky Glass TV and power back on again and it should work.
My little girls sending me nuts honest to god so stupid what other telly does this🙄🙄
This message was authored by Alisoneatt01 This message was authored by: Alisoneatt01
I cannot even get my tv to turn on after trying everything suggested even reset router   We have glass tv but watch through sky q which is working in the bedroom on a normal tv so not sure what is going on
This message was authored by Tracydee This message was authored by: Tracydee
Sky glass not coming on
Is anyone struggling to get sky glass on? Just red light on the front
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Sky glass not coming on
@Tracydee
I've moved your post into a large thread discussing this issue. See post 2, currently showing as the answer.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
Locked
