Discussion topic: Sky Glass Power up Issues 19-9-24
Message posted on 19 Sep 2024 05:53 PM
Re: Sky Glass Power up Issues 19-9-24
we are in Derbyshire and have same problem
Just spoken to someone , apparently they did a software update and that's thrown everyone out!! Why didn't they just leave it alone!! They are working on a resolution asap , but who knows how long that will be!
65"TV JUSTS FLASHS RED
Red light on front of TV just flashing
Re: Stream puck won't turn on
National issue we are midlands, same issue as everyone else
Message posted on 19 Sep 2024 05:54 PM
I'm Somerset
*following*
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
Message posted on 19 Sep 2024 05:55 PM
@Marie54 wrote:
But it would be helpful to know if problem being worked on and when it will be expected to be resolved
You typically won't get ETCs.
Also ETCs are fairly useless as with major tech outages like this ETCs are usually not known or if given by a company completely inaccurate ( unless they provide the ETC after they have already resolved the issue).
As these problems first require investigation into the cause of it before they can even work on a fix you never know how long it will take to identify the root cause of an issue.
Message posted on 19 Sep 2024 05:56 PM
If that is the cause, they all need to go back to tech school.
Re: Sky glass to not powering on. Tried reset not working. Sky on phone 50min hold time. Anyone kn
Been on to sky and it's an issue caused by last update. Will only be fixed by a further update whick they are working on
Sky Stream issue
Turned off my new stream box this afternoon to move it to better area, switch it all back on to sky flashing on my screen and the light flashing on the box.
any one know when the issue will be fixed?
Message posted on 19 Sep 2024 05:57 PM
Re: Sky Stream issue
@AaronJames wrote:Turned off my new stream box this afternoon to move it to better area, switch it all back on to sky flashing on my screen and the light flashing on the box.
Nope
Message posted on 19 Sep 2024 05:58 PM
Puk won't turn on or rest
