Discussion topic: Sky Glass No Wifi Connection
This message was authored by: AC1110
Have switched off Glass TV at mains for over 24 hours numerous times.
WiFi is working on all other devices, i.e phones, laptops, and tablets. Sky Advisor also did a reset. WiFi router has been reset / turned off and on at mains.
Keep getting same error that there is no WiFi connection.
As I have done a reset, it will not allow me to go to Settings so this is not an option. When the TV is switched on it is looking for WiFi connection, as soon as I choose the option with broadband password it says "No WiFi Connection"
Re: Sky Glass No Wifi Connection
Hi @AC1110
Have you factory reset the TV? As that should only be done with sky's guidence.. Sky have an article with a few things to try. Please see: https://www.sky.com/help/articles/connect-tv-help-sky-glass.
Is the signal marginal in the location where your glass TV is? The general recommendation would be to use an ethernet cable or home plugs for setup and permanently if feasible.
MikeAlanR
I'd agree with @mikealanr in this situation, try plugging in with an ethernet cable. Once conencted you may need to unplug the TV for a couple of minutes as well.
Avatar for AC1110
@MarkGoldsmith @mikealanr
Thank you both, I called Sky last Saturday and they advised to factory reset the TV. I followed all their guidance and still no luck. They told me they reported the error and would call me back in 24 hours. The TV is still not connecting to WiFi.
I do not have an ethernet cable. I only have WiFi, which is working on all other devices and the router is in the same room as the tv with good coverage on other devices. I have been without Sky TV now for over 1 week and no answers from Sky
To be honest i think the ethernet cable may be the only solution at this current point, as without the TV being able to establish an internet connection you can't even get to settings or anything else.
Its either that or phone Sky and request they replace it.
This message was authored by: Jporch316
@AC1110
you should have had an Ethernet cable with your router .....
This message was authored by: Helen5185
We've got the same issue! Thought I found a solution by turning on network standby mode but it was already on so no help there! It's so frustrating we are at the end of our tether with it now. No broadband issues at all so we do t even want the tv anymore! Pointless not be able to watch a tv we are paying nearly £100 month for!
