2
This discussion topic has been answered Discussion topic: Sky Glass Gen 2 Wall Mount
This message was authored by: Eagle58
I am looking at the Sky Glass Gen 2 65" TV, I currently have a 65" TV wall mounted on a Cantilever VESA bracket, I want to use the same bracket, does the Gen 2 accept a standard VESA mount?
This message was authored by: Anonymous Answer
Re: Sky Glass Gen 2 Wall Mount
Yes it can, just be sure that it can hold the weight because Sky Glass is quite a bit heavier than most TVs on the market at 26.5kg.
Avatar for Eagle58
Many thanks, I wasn't sure as the pics I have seen show a 'knock out' section at the back and I will need to use two bolt on arms that hook onto my main bracket, I'll be OK with weight as the bracket is rawl bolted with 20mm anchors x 4 and currently supports a Samsung 65" TV and a Samsung large sound bar. Thanks again.
Answered - Go to Answer
