Discussion topic: Sky Glass Air - No option to connect remote to speaker
Message posted on 05 Aug 2025 02:01 PM
My New sky glass air arrived yesterday - great TV so far - however I have run into an issue and I can't find anyhting to how to sort it.
On my old TV and sky puk, it was set up so I could change the sound bar on the sky remote, however, I have set the sound bar up to TV (sound on air is not quite as good as I expected) and the sound bar is set up and the sound plays through it not issues at all.
However, when I have gone to remote settings, it does not give me the option to set the remote up to control speaker volumes, I only have the option to reset control.
When i press the volume buttom, it is showing that the speakers are through the optical cable, but I can't change the volume or connect to speakers, I thought about using my old sky soundbar with hdmi cable, but I can't see that working either as there is no options to connect, like there used to be with the puk.
Message posted on 05 Aug 2025 02:49 PM - last edited: 05 Aug 2025 02:51 PM
Re: Sky Glass Air - No option to connect remote to speaker
Unfortunately Sky and Devialet didn't see fit to specify the Soundbox for ARC, so it cannot be directly connected to the ARC HDMI socket on a Glass or Glass Air.
