4
This discussion topic has been answered Discussion topic: Sky Glass 2 Stand Dimensions
This message was authored by: inasnum
Hi all, anyone with a 55" Sky Glass 2? Could you let us know the size of the stand. Need to know the footprint of the stand to see if it will fit on existing unit.
This message was authored by: Carnoch04 Answer
Re: Sky Glass 2 Stand Dimensions
80cm X 21cm approx.
Sky Stream since launch with Philips 55" Mini LED. Sky Glass Gen 2 55" now added.
80cm X 21cm approx.
Avatar for inasnum
Level 3 icon
Will it fit?
This message was authored by: bluecandylover
Hi.
Is the size of the stand the same for the 65" model? Thanks
