Discussion topic: Returning Sky Glass after 3 months due to not being able to connect my Sonos
Message posted on 06 Sep 2024 04:49 PM
I came back to Sky in May and was informed my the Sky advisor that I should be able to connect my Sonos.
After 3 months of spending money on various stuff and trying different techniques - it still doesn't work.
I want to now return it and get a TV which supports my Sonos and get a Sky Q box.
can anyone advise on this?
Message posted on 06 Sep 2024 04:58 PM
Re: Returning Sky Glass after 3 months due to not being able to connect my Sonos
@Simon2024 You can't returned unless you can prove it is unfit for purpose under the consumer act or lodge an official complaint over mis selling
Message posted on 06 Sep 2024 05:18 PM
I know they record all telephone conversations so if I ask for the transcript it should show that they used the words "Should work with Sonos". Maybe I go down that route.
Message posted on 06 Sep 2024 05:41 PM
Glass should work with a Sonos soundbar connected via ARC/eARC (although there have been issues with Atmos content, not sure if that ever got resolved). Glass won't work with any other Sonos speakers directly.
which Sonos device are you trying to get working with Glass?
Message posted on 06 Sep 2024 05:53 PM
I have Sonos generation 3. I Have ordered 2 separate eARC to optical audio extractors - no success 😒
Message posted on 06 Sep 2024 05:59 PM - last edited: 06 Sep 2024 06:00 PM
@Simon2024 being honest im not sure that saying should be is the same as saying it will definately work now if the advisor said it would definately work or it will work then I think you would have a claim on being mis-informed but should leaves a small element of doubt that it will work.
Although there is no harm in trying to contact Sky and see what they say
Message posted on 06 Sep 2024 06:00 PM
Sky Glass should only really be considered if you like the aesthetic of the TV and plan to use the built-in soundbar for space-saving reasons.
If you always planned to use external speakers then you'll get much better value and versatility from any other decent modern smart TV with (or without - other services are available) a Sky Stream puck attached to it.
