Discussion topic: Remote
Message posted on 13 Feb 2025 10:54 PM
Remote
Anybody know how I get the voice to work on my remote?
I've tired rebooting the remote, restarting the sky stream box and nothing, it says "that didn't work, please try again" when I try to use it
Message posted on 14 Feb 2025 07:18 AM
Re: Remote
What kind of commands are you asking? Have you tried restarting the box?
Message posted on 14 Feb 2025 09:00 AM
Re: Remote
Yes I have, still won't work when I speak into the remote using the voice button
It's brand new so it can't be broke
Message posted on 14 Feb 2025 09:14 AM
Re: Remote
@Nellie97 wrote:Yes I have, still won't work when I speak into the remote using the voice button
It can be brand new and broken. There were lots of problems with some of the first batches of remotes sent out with Sky Stream pucks a couple of years ago. You may just have been unlucky and got a random one that wasn't soldered properly inside.
Give Sky a ring and they'll send you a replacement.
Message posted on 15 Feb 2025 08:48 PM
Re: Remote
Oh really!
that's good to know, thankyou I'll do that as soon as I can🙌🏽
