Discussion topic: Remote numbers are not the correct channels
This message was authored by: Shazz1607
Each time I try to go on a channel I want it's not in number order ! Why ?  And how do I fix it
Re: Remote numbers are not the correct channels
Hi @Shazz1607
It could be that you have some how set up favourites. See: https://www.sky.com/help/articles/using-favourites-on-sky-q#:~:text=Accessing%20your%20Favourites&te....
Try removing favourites as per the instructions. If that doesn't work, try unplugging the your glass for a few minutes at the mains and plugging it back in.
If that doesn't work, try re-pairing your glass remote: https://www.sky.com/help/articles/remote-control-help-sky-glass
And if that doesn't work, you can order a replacement remote under warranty here: https://www.sky.com/help/forms/streaming-tv-remote
Hope this helps.
MikeAlanR
