Discussion topic: Remote not working sky stream
This message was authored by: Amrik3
My sky stream remote is not working
Batteries drain quick need to change everyday
Re: Remote not working sky stream
@Amrik3 See the online help here:
Sky Glass or Sky Stream remote isn't working | Sky Help | Sky.com | Sky Help | Sky.com https://share.google/kevn6mMpDJGmWzWPY
My batteries in both my pucks that get daily use and have lasted just over 12 months.
I replaced the ones that came with my pucks on day one and changed to Duracell Power plus alkaline.
The batteries should last many months, so running out daily, would look at a new set of alkaline batteries.
Plus do a re pair once you've added your new batteries.
  1. Press and hold 7 and 9 together for 3 seconds.
  2. Press and hold 1 and 3 together for 3 seconds.
  3. Wait until you see the 'Your remote is now connected' message and select Continue
https://www.sky.com/help/sky-tv/sky-tv-stream/fixing-a-problem-sky-stream/fixing-sky-glass-remote/ar...
@Amrik3  The batteries in my remote were only lasting a few weeks and I contacted Sky who sent me a replacement and I had no problems after that.  Try the advice given by the other posters in this thread and if it is still not working request a replacement.
