4
This discussion topic has been answered Discussion topic: Recommendation for a swivel bracket to hold 55" Glass TV
This message was authored by: dda25
We have used the tv bracket on the back of the sky glass but would like a swivel one. Does anyone know of any make and model that would hold a 55" Sky Glass TV please?
This message was authored by: mikealanr Answer
Re: Recommendation for a swivel bracket to hold 55" Glass TV
Hi @dda25
I don't have any specific recommendation, however Glass is compatible with any standard VESA mount. The only thing you have to make sure is it's rated for the weight, as Glass it a heavy beast. The 55" is 23kg without the stand.
https://www.sky.com/glass/technical-specifications?dcmp=knc-uk-ppc-ggl-18336142757-ACQ-Glass-Trading...
MikeAlanR
Hi @dda25
MikeAlanR
Avatar for dda25
Thank you very much for your  help👍😁
@dda25
Be aware that any such mount exerts a really significant force on the wall bolts through the principle of leverage.  While the bracket itself can easily be rated for the weight of a Glass set, it's the fabric of the wall itself which is the most likely point of failure.
Avatar for dda25
Thank you for that. Will take that into consideration 👍
