Discussion topic: Problems with sky glass live TV
This message was authored by: AlisonB2
Hi our sky glass has been working fine until recently when the picture keeps stopping and freezing and the sound goes off
Re: Problems with sky glass live TV
Hi @AlisonB2
Has something changed such as your WiFi channel? Who is your ISP and broadband speed? Sky glass needs 25Mbps for HD and 30Mbps for UHD. You can run a speed test in netflix by opening the menu > scroll down to get help? > Select connection check.
Have you tried a reboot in the first instance? You can do this by going to settings > system management> resets & updates > reboot.
MikeAlanR
Avatar for AlisonB2
It has been working fine up until now and we have not changed the broadband - that's with sky but I believe open reach are provider - tried switching off and on and rebooting the broadband - seems to only be an issue on live TV
@AlisonB2 did you try the speed test as @mikealanr suggested? The wifi channel your router is using can change automatically and you wouldn't necessarily know until one or more devices start to have problems.
