Discussion topic: Problems powering on sky glass gen 2
Message posted on 07 Jul 2025 06:59 PM
Whenever the TV is off for a good couple of hours, it won't power back on. I've tried voice activating it and using the remotes but only the power indercater would flash, its happend twice now but it's not consistent. Is this a software bug or something wrong with the hardware?
Message posted on 07 Jul 2025 07:03 PM
Re: Problems powering on sky glass gen 2
I will try get back as soon as possible
Message posted on 07 Jul 2025 07:08 PM
@C-bushrodglass Try each of the steps here:
Sky Glass TV won't turn on or it's stuck on standby | Sky Help | Sky.com | Sky Help | Sky.com https://share.google/DbMHgBWfYHXCdBxVz
If they don't resolve it then you'll need to ring Sky for help.
Message posted on 07 Jul 2025 08:16 PM
When is the last time you pulled the plug for a few minutes ?
might clear it if it's a software glitch
