Discussion topic: Problems disconnecting to WiFi
This message was authored by: Jofay83
Tv disconnects from WiFi, remote control is slow and just won't work. Apps are not connecting and no way to uninstall and reconnect.
Re: Problems disconnecting to WiFi
Hi @Jofay83
Who is your ISP? Generally slow performance can be attributed to poor broadband speeds or poor stability between Glass and router. You also need 25Mbps for HD and 30Mbps for UHD.
One thing to try is go into settings > startup and standby and enable "Network Standby Mode". This will try to keep the connection alive between router and Glass when in standby.
In terms of apps. Entertainment OS is a managed platform. There is no way to install or uninstall apps. You can however force a refresh of apps in the system management > resets and updates menu. Note refresh apps can take up to 24 hours.
MikeAlanR
