6
This discussion topic has been answered Discussion topic: Please wait for programme to load sky stream
This message was authored by: Jonathan85
I'm having problems with that message popping up please wait for programme to load sky stream I chatted to sky help team and they told me if that keeps happening it's down to the Internet connection so they asked me how was it connected either by WiFi or Ethernet cable so I said Ethernet via hub tried it today same thing happened again on gold it was settled yesterday no trouble many thanks
This message was authored by: MarkGoldsmith Answer
Re: Please wait for programme to load sky stream
@Jonathan85 You have mentioned you have connected via an Ethernet cable int and case have you also disabled WiFi in the settings? These Sky devices for some reason will default to trying WiFi if it's enabled even if you have an Ethernet cable plugged in.
What is your router sync speed to the internet?
What is your device's connection speed to the internet?
What devices are connected and using your internet bandwidth?
Avatar for Jonathan85
Level 3 icon
The current speed is 37.5 and the rest of the info I'm not sure about the hub speed is unknown not quite sure of the info of the rest of it
Level 3 icon
Which one should I use then no I haven't disabled WiFi in the settings it says connected via puck in networks/settings
37.5 where did you get that number from.... did you measure the internet connection speed on the Sky Stream device a few times a few minutes apart.... you are unlikely to get a single constant value😉
So if you are connected via Ethernet disable the WiFi and see if that helps.
