3
This discussion topic has been answered Discussion topic: Only had sky glass for a few months and sometimes the picture sticks and sound. It freezes.
This message was authored by: Chantal59
Only had sky glass for a few months and sometimes the picture sticks and sound and freezes. What can be causing this to happen.
C.A.Taylor
This message was authored by: MarkGoldsmith Answer
Re: Only had sky glass for a few months and sometimes the picture sticks and sound. It freezes.
Firstly what internet speed are you getting generally, as you need to eliminate the cause being inadequate speed coming into your property?
Then the next step is to run a speed test from the Sky device, open Netflix on the Glass, go to Get Help -> Check Your Network and it will run a diagnostic and tell you the speed the Glass is getting.
Inadequate connection speed between the TV and the internet🤔
Avatar for Chantal59
Level 2 icon
Thank you for the replies. The problem seemed short lived and haven't had any trouble for two days now. Made a note of all replies.
C.A.Taylor
