This discussion topic has been answered Discussion topic: On switch on the sky glass has fogotten apps and ethernet connection
Message posted on 05 Jun 2024 05:12 PM
Our sky glass 55 system has developed a strange couple of issues:
1, When switching on the system thinks that it's not connected to Internet via the ethernet cable . Use the on screen option to connect, and the system is connected - weird
2, Continue to the recently used Apps screen and they have all disappeared. Apps have to be added and accessed again
This has happened a few times now and early this morning the system would not connect to the Internet
Any help would be appreciated, thank you
Message posted on 05 Jun 2024 06:49 PM
@Debonsteve59 With regards to your point 1. I'm assuming this is the same issue I had with Sky Glass. Every morning when it was switched on it said there was no network and we needed to switch it off via the remote and back on again. We resolved this by going into settings > Startup and Standby menu and switched on the Networked Standby mode setting. This stops the TV fro losing the network when it goes into standby.
Message posted on 05 Jun 2024 07:57 PM
Re: On switch on the sky glass has fogotten apps and ethernet connection
Thank you, that makes sense. I'm taking that there has been an upgrade and this has made changes to my settings
I'm hoping that the Apps will now Stay in Place
