4
Discussion topic: On demand movies freeze and make a loud stutter noise
This message was authored by Welshy1 This message was authored by: Welshy1
When watching a film last night twice the TV froze and a loud stutter noise was made then after 2 mins the TV restarted. We started the movie again and it worked again for 10 min then did it again.
This message was authored by Fothergill1 This message was authored by: Fothergill1 Answer
Re: On demand movies freeze and make a loud stutter noise
@Welshy1  You possibly have a situation similar to one I experienced once with my Sky Glass.  The picture froze with a pixelated image and the sound stuck with what I can best describe as a machine gun sound.
I unplugged my Glass for about a minute and then reconnected it but this didn't work so I unplugged it for a further 10 minutes and this cleared the issue which never happened again.
If that doesn't help I would contact Sky for some additional troubleshooting.
If my post has solved your issue please mark as an "Answer"
