Discussion topic: No sky but tv stuck on reset
This message was authored by: Kellie2024
Hi pls help I have a sky glass tv but don't have sky at all, it's stuck on the reset bit so can't even use normal Ariel
thanks
Re: No sky but tv stuck on reset
Try turning it off at the plug for 10 minutes
Avatar for Kellie2024
Level 0 icon
I have turned it off for days got Vodafone broadband but won't finish loading
Have you tried connecting it via Ethernet cable to the router?
This message was authored by: peter-marlow+1966
Are you  doing  a factory  reset ?  If so you  need  to  contact sky  for help,
P c marlow
