This discussion topic has been answered Discussion topic: No broadband, would a wifi tv dongle work?
Message posted on 11 Jan 2024 01:06 PM
Re: No broadband, would a wifi tv dongle work?
The "Tekeir Universal Smart TV WiFi Dongle" does not have a sim slot😉
Message posted on 11 Jan 2024 01:37 PM
Thank you so much for your help, I'll see if I can get a sim that does it month by month as I only need it for up to 3 weeks.
Message posted on 11 Jan 2024 01:45 PM - last edited: 11 Jan 2024 01:48 PM
As noted, it's probably best to move in first and then check the indoor cellular signal before ordering anything. All this is moot if the local mast cannot provide enough bandwidth for Glass to stream reliably.
For the DTTV tuner in the Glass set to function you'd need an aerial of some kind: reception quality and channel availability will depend on the local Freeview multiplex.
Message posted on 29 Feb 2024 10:27 AM
Like Shez, I have a Sky Glass TV and no wifi activation until end of March. I do have a Vodafone 4G mobile Hotspot (Model R228t) which I would like to use to activate the Sky Glass TV. IS this possible and if so, how do I configure the TV to use the mobile hotspot device. Thanks in advance Alex
Message posted on 29 Feb 2024 10:39 AM
@Al62 wrote:Like Shez, I have a Sky Glass TV and no wifi activation until end of March. I do have a Vodafone 4G mobile Hotspot (Model R228t) which I would like to use to activate the Sky Glass TV. IS this possible and if so, how do I configure the TV to use the mobile hotspot device. Thanks in advance Alex
It may be possible, but would depend on how strong and stable a WiFI signal your Vodafone device can produce. Sky Glass relies entirely on having a fast and stable connection so you may struggle, particularly during the initial software download stage, to maintain a decent enough connection.
You would also need to make sure you had plenty of data allowance available (preferably unlimited) as these TVs will chew up a lot of gigabytes very quickly.
If you want to try it then all you'd need to do is activate the hotspot and connect Glass to the WiFi network generated by it by following the on-screen prompts when you turn the TV on.
Message posted on 29 Feb 2024 12:10 PM
Note that HD viewing on Glass will eat several gigabytes an hour, and UHD considerably more.
Message posted on 09 Nov 2025 01:22 PM
Hi, looking for guidance please. Our BT router/hub was checked out a while back by BT engineer. Cutting a long story short, our Sky TV service doesn't have Catch up facility or related due to the hub being in a different room. The engineer said Sky can provide a dongle to resolve this issue... I don't expect anything for free from them TBH so could anyone identify the dongle or advise of a suitable alternative, please?
Many thanks
Message posted on 09 Nov 2025 02:33 PM
That's probably a reference to the 'Q booster': there isn't an equivalent for Glass/Stream.
Message posted on 09 Nov 2025 02:44 PM
Thanks but it isn't Sky Q or Glass. The engineer was adamant a relevant dongle would help.
Message posted on 09 Nov 2025 05:27 PM
Unfortunately the slang use of that word can refer to multiple things: it's most often a USB attachment of some kind, which isn't relevant in this context.
