Discussion topic: My5 won’t load on on my Sky Glass
Message posted on 18 Apr 2025 08:51 PM
Re: My5 won’t load on on my Sky Glass
Regarding previous message: it is like when you go off the app in the first place it is not actually closing down correctly which then leads to problems reloading the app unless you restart device which forces the app to close down.
Message posted on 19 Apr 2025 01:24 AM
Hi @MartinV
Mine is Sky Stream.
Yes this is correct! I had logged in on Channel 5 app & was watching a few episodes of a series. After I had left for a while & tried to reconnect, it just tries to load, but nothing happens.
My 5 & 5 were merging together at the time. So I'm not sure if this affected it!
So therefore I came to the conclusion also that the app can't seem to close down correctly.
I received a message from Sky which told me to re-boot everything & then re-sign in to all apps.
I followed this & nothing happened at all. Sky said they had hoped that would solve the issue. As it didn't they stated they knew there was an issue, But they couldn't help any further in regards to it.
I hoped they could of done something on there end. But this isn't possible..
So if anyone finds an issue, I'm waiting ☺️
Message posted on 19 Apr 2025 08:18 AM
In the end I had to factory reset my sky glass and reset it up. This fixed the problem. It is a little onerous as you have to relog into apps such as Netflix and Amazon Prime but you can quickly reconstruct your watch list as it seems to retain them after the reset.
Message posted on 19 Apr 2025 10:09 AM
I did a factory reset begrudgingly and. It worked for now
Message posted on 19 Apr 2025 12:04 PM
Message posted on 19 Apr 2025 12:29 PM
Hi
I also did a factory reset this morning and so far seems to be working. Thanks for the advice all
Message posted on 04 May 2025 03:26 PM
I've been having problems since Jan 5 app won't open will sometimes let me watch 1 episode of a series then I have to keep refreshing the app it's getting beyond a joke
Message posted on 29 May 2025 11:45 PM
I am having issues I've tryed reset, I see yours was in January have you resolved this issue or did it just work by itself,
or still not working ?
many thanks
Message posted on 29 May 2025 11:46 PM
Same issues here
Message posted on 30 May 2025 09:10 AM
For those who missed my earlier comment, I did a factory reset. That resolved the problem, but has the incovience of having to relog into apps such as Netflix. The watch list seem to reconstruct itself. I haven't had any problems since then.
Message posted on 30 May 2025 01:00 PM
I've done a factory re-set & unfortunately this hasn't resolved my issue with 5 App. So I'll have to re-try again!
How have you been able to re-fresh the 5 App?? I've done it through the settings. But this has done nothing. So just wondered if I was missing anything??
Thanks x
Message posted on 30 May 2025 01:35 PM
@Harves It can take up to 24 hours for the refresh apps to process.
