Discussion topic: My toddler has some how managed to smash a part of our sky glass TV and now the screen doesn’t work.
This message was authored by: ThePope27
Re: My toddler has some how managed to smash a part of our sky glass TV and now the screen doesn’t w
@Laing1
Yes its been addressed i made a typo......
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
@Laing1
Edit my post then...
@ThePope27 wrote:
@Laing1
@ThePope27 I was only pointing it out to you so you know for future reference and superusers cannot edit other users posts
But superusers can change other peoples answers tho can't they 🤬
@ThePope27 yes superusers can amend answers, where the incorrect post has been picked as the answer a superuser can amend it to the correct answer
Seems like certain people are abusing that...
@ThePope27 The correct answer has to marked to let others with the same problem know what the full answer is
as  some people, mark their response as the answer when its not,  others mark the first response as the answer when it might not be correct  sometimes the first correct answer is missed by the op other times although an post is marked as the answer its not completely correct and a fuller complete explanation is marked as the answer.
I've had many of mine changed by other superuser and Sky staff and have changed some of my own  from being correct as it was the first answer and wasn't what actually helped helped the op
@Laing1  I know this has been discussed elsewhere but I would be in favour of the wording being changed from "Answer" to "Solution" as this would remove a lot of the confusion..
If my post has solved your issue please mark as an "Answer"
