Discussion topic: My sky glass will not connect to sky
Message posted on 30 Oct 2024 05:47 PM
I left sky in September 24.
I rejoined sky in October but since rejoining sky my sky glass tv will not get sky I need an engineer to come and check my tv. It accepts certain apps but still won't work on sky?
Does anyone have any idea what could be wrong I have no mobile phone?
Message posted on 30 Oct 2024 06:12 PM
Re: My sky glass will not connect to sky
@aussie1234 wrote:I left sky in September 24.
Hi
have you tried to reset the network connection in the network settings ?
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
Message posted on 30 Oct 2024 07:14 PM
Hi thanks for your reply.
Yes I have tried but it already says it is connected so no help there?
Message posted on 30 Oct 2024 07:36 PM
@aussie1234 Sky have no engineers for Sky Glass as it's a self install & setup product.
If the suggestion by @Jporch316 isn't workimg I would give Sky a call, they may take you through a full reset
Message posted on 30 Oct 2024 07:45 PM
Thanks for your reply.
I have gone through with one agent but she did not know enough as it was 8.40 all she was concerned about was she was finished at 9pm so I got no help from here?
So I have paid over the odds for a tv which sky engineers can't or won't repair?
I'm now annoyed that I rejoined sky a few days ago so I think I should just quit sky again they are useless.
Message posted on 30 Oct 2024 07:49 PM
@aussie1234 Again there are NO engineers for Glass. You will need to speak to Sky again. You;re TV doesn't need a 'repair', it simply needs setting up or a full hard reset which should only be done on the phone with Sky.
Message posted on 30 Oct 2024 08:59 PM
I'm trying to contact sky via email as I currently do not have a mobile phone it's being repaired.
Try to contact sky online is almost impossible as it's all automated unless someone can advise me of the customer service number?
Thanks for your reply much appreciated.
Message posted on 30 Oct 2024 09:01 PM - last edited: 30 Oct 2024 09:02 PM
@aussie1234 Sky don't use email as a form of communication, however we can escalate this to the messaging team if you wish who will pick this up tomorrow.
