Discussion topic: My sky glass keeps showing a technical fault and going to a blue screen on all channels
This message was authored by: Kate1231
Message posted on 27 Dec 2023 09:10 PM
My sky glass keeps saying technical fault and then the screen is going blue on all channels
Find out more
Message posted on 27 Dec 2023 09:14 PM
Re: My sky glass keeps showing a technical fault and going to a blue screen on all channels
Hi @Kate1231
Try powering it off for a few minutes at the plug and try again. If it continues to happen it could be network related. How is your Glass connected to the internet (WiFi / ethernet?) What speed is your connection etc.
You can run a speed test within the settings of the netflix app, this will show you the throughput the glass is getting.
MikeAlanR
55" Gen 2 Sky Glass atlantic blue, 65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Sky SoundBox. Former Sky Q, Sky+ HD and Sky+ customer.
