Discussion topic: My sky glass is saying there is a technical issue
Message posted on 21 Apr 2024 08:24 AM
Ive turned my sky glass tv on and it says, Sorry, because of a technical issue, youre currently experiencing a limited service. Please be assured that were working hard
to fix the problem.
Message posted on 21 Apr 2024 08:36 AM
Re: My sky glass is saying there is a technical issue
I'll move your post from the Sky Q board.
Message posted on 21 Apr 2024 08:41 AM - last edited: 21 Apr 2024 08:42 AM
@Francesca00 Have you checked your netowk settings in the Glass settings menu?
Go to settings --> Standby and startup --> Networked standby mode = set to on.
Check Overnight Power saving is set to off.
Message posted on 21 Apr 2024 08:56 AM
Might be worth pulling the plug from the wall for 5 minutes .....
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
