Discussion topic: My sky class keeps freezing and going off
Message posted on 18 Apr 2024 06:55 PM
Message posted on 18 Apr 2024 08:58 PM
Re: My sky class keeps freezing and going off
Freezing is usually the result of an unstable internet connection going to the Sky Glass. Do you have it connected via Wifi or ethernet?
Message posted on 12 Jun 2024 08:56 PM
Message posted on 12 Jun 2024 09:07 PM
@JOSH24680 wrote:
Yes I do
I take it by this comment you have it connected via Wifi.
In that case the first test to perform to check if the problem is your Wifi network is to connect it to the internet via an ethernet cable. When doing this you should disable the Wifi in the Glass Network settings and then give the Glass a reboot by turning it off at the plug for a couple of minutes.
If this solves your problem then the issue is related to the strength and stability of your Wifi network. If that doesn't solve the problem it could be a few other things but this is generally the best test to do first.
Message posted on 12 Jun 2024 09:19 PM
