26 Jan 2024 04:31 PM
My glass motion sensor has not been working for last few days -all settings I believe are correct - when it did work you had to be very close to tv to activate sensor - any advice please
26 Jan 2024 05:17 PM
@Mrben333 wrote:My glass motion sensor has not been working for last few days -all settings I believe are correct - when it did work you had to be very close to tv to activate sensor - any advice please
Have you tried fully rebooting the TV? Turn it off at the wall for a good ten minutes then power it back on and see if that helps. Doing this can often temporarily fix glitches such as this.
26 Jan 2024 07:07 PM
Hi yes I have tried this and it is still the same
27 Jan 2024 06:44 AM
How old is the Sky Glass TV?
27 Jan 2024 09:51 AM
About 1 year
27 Jan 2024 10:41 AM
Have you reported the issue to Sky... better sooner than later🤔
