7
This discussion topic has been answered Discussion topic: Manual tuning channels on Sky Stream/Glass
This message was authored by: 31SHP
Recently upgraded to Sky Glass and another Tv with a PUCK, any idea how I manually tune channels like ITV that aren't standard in Ireland?
This message was authored by: GD1 Answer
Re: Manual tuning channels on Sky Stream/Glass
@31SHP  You simply can't "Tune channels in" your on a streaming platform and the channels provided are allocated based on your location.
In the republic of Iteland you get only the channels such as RTE, ITV don't stream outside the UK & Northern Ireland.  Stream is a different system to satellite.
Hi @31SHP
It isn't possible, the channels are delivered by the internet and the isn't a satellite tuner in the box only a DTT tuner, however this is disabled in all territories except Italy.
MikeAlanR
To use the DTT tuner in Sky Glass TV disconnect the TV from the internet🙂
This message was authored by: Paul+Boland
@Exiled-in-HH
Sky Glass DTT Saorview tuner will not receive  ITV channels in Republic of Ireland using an tv aerial.
Saorview TV Channels
https://saorview.ie/en/television/
Virgin Media Channels has the broadcast rights for some but not all ITV content in Republic
Customers in Republic of Ireland  might be able to pick up UK Freeview channels using a tv aerial if they are very close to the border with Northern Ireland.
To get arround ITV channels not on Sky Sky Glass/Sky Stream in Republic of Ireland
I use my Sky HD Satellite Box as a free to air satellite receiver to get UK channels like ITV etc
You just need to make sure you have hybrib lnb on the satellite dish if you preiously has Sky Q installed
I have my SKY HD Box connected to my AV receiver that is then connected to HDMI 2 on Sky Glass
@mikealanr
DTT tuner been disabled only applies to Sky Stream Puck
Sky Glass
DTT tuner is not disabled in UK or Republic of Ireland
It will become active when there is no internet connection.
@Paul+Boland UK. TV channels don,t broadcast on ROI transmitters is hardly surprising they can not be receiver on the Sky Glass TV's DTT tuner🤔
