03 Mar 2023 07:01 PM
Help me please
03 Mar 2023 07:04 PM - last edited: 03 Mar 2023 07:04 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Paul2309
Unfortunately you will have to use search on Sky Glass to try and find what you previously had.
There is no transfer method available when swapping from Sky Q and everything gets lost unless it's Sky Store content which you access via the app.
Thanks,
Tim
Posted by a Superuser, not a Sky employee. Find out more@Paul2309 Your post doesn't give us much to go on
but if you mean you can't access all channels on glass that you could on Q , that'll be because the line up of channels is completely different
03 Mar 2023 07:06 PM
Sky Glass and Stream do not have the same channel line up as Sky Q.
Any recordings on Q will be lost when your Glass subscription became active.
What exactly is your issue ?
