Discussion topic: Last few days, technical fault with channel, disney plus etc works.
Message posted on 18 May 2025 08:10 AM
Re: Last few days, technical fault with channel, disney plus etc works.
Issue free for a couple of days now, haven't used prime since it was highlighted by you guys, let's see what happens when I log into prime again........
Message posted on 18 May 2025 08:13 AM
I'm finding that I don't need to actually sign out of Prime. I just open Prime and watch a couple of minutes of a stream then I can switch over to any other Sky channel and it "seems" to be functioning normally.
Message posted on 18 May 2025 08:22 AM
@MarkP65 Yes, but when I was doing that I had to do it each morning. Signing out of Prime has fixed it permanently, it seems.
Message posted on 18 May 2025 08:23 AM
Ah ok. That's worth a try until Sky provide a fix
Message posted on 18 May 2025 08:49 AM
So, we think we've established that signing out of Amazon Prime solves the problem. That's fine for me, as I have a Google TV plugged in that I can use for Prime - others are using a firestick. But it's not an acceptable solution for a product that is marketed as all-in-one. All of the installed Apps should work seamlessly with the Sky OS. Sky need to sort this out properly, but it's clearly proving to be a tough job.
Message posted on 18 May 2025 08:53 AM - last edited: 18 May 2025 08:55 AM
@Blue+Dog wrote:So, we think we've established that signing out of Amazon Prime solves the problem. That's fine for me, as I have a Google TV plugged in that I can use for Prime - others are using a firestick. But it's not an acceptable solution for a product that is marketed as all-in-one. All of the installed Apps should work seamlessly with the Sky OS. Sky need to sort this out properly, but it's clearly proving to be a tough job.
Maybe it's worth investigating if an app refresh (in the glass settings can take a few hours to complete in the background) would permanently fix the issue
also worth signing out and deregestering the glass tv on the prime web page then register it
unfortunatley there doesn't seem to be any settings within the prime app to clear the cache or reset the app (like in the native Netflix app)
Message posted on 18 May 2025 09:02 AM
@Jporch316 Really good suggestions 👍
Message posted on 18 May 2025 09:05 AM
@Blue+Dog wrote:but it's clearly proving to be a tough job.
One of the reasons its could be taking longer to fix is if its requiring a fix to the Prime Video App, which means its a fix that Amazon need to be producing and testing before its released.
Historically issues that have been attributed to third party apps have typically taken longer to get fixed that if the fix was solely the responsbility of Sky. You can find a handful a examples on this forum alone when specific issues with some of the third party app ( including some for Prime Video) have unfortunately taken a few months to get fixed.
Message posted on 18 May 2025 09:16 AM
@MarkGoldsmith That makes a lot of sense.
Message posted on 19 May 2025 07:04 AM
Second morning everything has worked. I have not touched Prime since I signed out and reset on Saturday. So it seems either I do not use Prime and Glass works, or I use Prime and have to reset the TV every day. Unsatisfactory either way.
Message posted on 19 May 2025 07:40 AM
@SkylerSky Agree completely. Third morning without problems for me, after signing out of Prime.
Message posted on 19 May 2025 09:47 AM
Sky glass problems
Every day this week When i turn the Sky Glass on, in the morning it comes up with the error page, i go to put a channel on and it says ‘ please wait for your programm to load ‘
Have to unplug Tv when it starts up I have a picture , but then a blank screen appears sometimes with sound sometimes not I then go to reset picture several times I do this and eventually it works I have a picture which lasts to the following morning ??
Message posted on 19 May 2025 09:56 AM
Re: Sky glass problems
@Phil205 Read the marked answer in this thread and the last few pages for a workaround that may work until Sky issue a fix for this firmware issue:.https://helpforum.sky.com/t5/Sky-Glass-Live/Last-few-days-technical-fault-with-channel-disney-plus-e...
Message posted on 19 May 2025 10:00 AM
Have moved your post to this current ongoing issue thread.
Read the more recent posts and the answered post within this thread from Sky on the issue and fill out the form as mentioned in the answered post.
Sky are investigating and we as Superusers are keeping them aware of many others having the issue.
Message posted on 20 May 2025 07:52 AM
Re: Sky glass
Finally it's now working . Called yesterday to say I wanted to cancel my subscription and a really helpful guy talked me through doing an update which I've tried before but it appears to have worked this time and all is good.
My faith may have been restored in sky Tv's service.
