Discussion topic: Last few days, technical fault with channel, disney plus etc works.
Message posted on 12 Apr 2025 10:06 AM
Re: Last few days, technical fault with channel, disney plus etc works.
Message posted on 12 Apr 2025 10:12 AM
Yes same again today, unusable. Just not good enough.
does the hard reset loose your playlist etc?
Message posted on 12 Apr 2025 10:31 AM - last edited: 12 Apr 2025 10:32 AM
@wsimm No, you will not lose your playlist but you will need to re-set up your settings like turning WiFi off if you use ethernet, turn off auto standby etc.
The technical staff will talk you through it. It's an easy process but you need to be on the phone with them in case of problems.
Message posted on 12 Apr 2025 11:29 AM
Re: Sky Glass Technical Fault AM
@Staceymay88 Have you rung Sky about this? I did and since doing a hard reset on the phone with them I have not had a reoccurrence. It seems to be happening to a fair few customers of the past few days so the more people that log it directly with Sky then better.
Message posted on 12 Apr 2025 03:38 PM
Did the reset via call with Sky after they looked at error messages etc. has been ok last few times i've switched tv on and gone through channels, will try again tonight
annoying i lost my settings for picture, preferences etc
Message posted on 12 Apr 2025 04:43 PM
Sky Glass will not load programmes
In the past couple of days I have had a continual problem with programmes failing to load, usually culminating in a technical fault message. I have been through the reboot process multiple times; spoken to Sky helpline all to no avail. This is not a cheap service and I am really disappointed that this problem is ruining my viewing experience. Every time I want to watch something I have to reset the system, even then it occasionally fails to solve the problem.
I have been through the troubleshooting process multiple times, my broadband is fast enough and stable. Can anyone from Sky help because at the moment it seems that nobody from Sky seems to care or know how to solve the problem. In the meantime I am paying for a useless heap of junk and it isn't cheap!
Message posted on 12 Apr 2025 04:48 PM - last edited: 12 Apr 2025 04:48 PM
Re: Sky Glass will not load programmes
Firstly.
Can you do a network speed test on your Sky Glass TV and any of your Pucks, if you have them.
Launch Netflix on yiur Sky Gkass tv or pucks (you do not need to be logged into it, if you do not use netflix) and scroll down the left menu to Get help.
Choose Check Network.
Would suggest running the test a few times, say a hanfpdful of times over an hour period..
What is your speed?
Would suggest also trying a restart of your Sky Glass Tv or pucks.
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Glass tv or puck will perform a reboot. It will take a few minutes to complete
Message posted on 12 Apr 2025 04:54 PM - last edited: 12 Apr 2025 04:57 PM
Lots of us have been having similar issues.
A few days ago I spoke with Sky Technical who talked me through a hard reset of the TV (you lose your picture settings etc but not your playlist). I've not had any problems since, touch wood. It's a bit more effective than the basic reset process.
If connected by ethernet and you do a hard reset make sure to go into settings and turn WiFi off.
Might be worth calling them and doing the same. It is an easy process but you need to be on the phone with them in case there are issues.
Message posted on 12 Apr 2025 05:00 PM
@jimmarten2015 Have you spoken to Sky Technical and got them to do a hard reset with you? If not it's worth making the call and going through that process with them. It solved my issue to date.
Message posted on 12 Apr 2025 05:37 PM
Yep I have the same problem as well
Message posted on 12 Apr 2025 05:46 PM
@Leam210 I refer to my previous replies. It seems the only solution is a hard reset, which should only be done speaking to Sky in case of problems.
Message posted on 12 Apr 2025 06:26 PM
So, now we have to leave it feeding the ulitily bill 24/7, to have a functional TV? This has to be a joke. How about SKy fixing this instead?
There is no reality where I'll ever upgrade to another Sky TV. The quality issues that are never fixed is astounding, be it this or HDMI devices with sound out of sync. Stuttering video on what I suspect is "too popular" broadcasts, bluetooth connections that keeps being forgotten. We can't spend 15 minutes every day factory resetting a TV to get basic expected functionality.
Message posted on 12 Apr 2025 10:43 PM
Sky glass not loading channels
Message posted on 12 Apr 2025 10:46 PM
Re: Sky glass not loading channels
Try unplugging the tv for about minutes and see if that works if not give sky a call in the morning
Message posted on 13 Apr 2025 06:09 AM
It's getting a joke this only a few days ago had to do a hard reset to solve my 5 issues and now having to do one again
