709
This discussion topic is read only This discussion topic has been answered Discussion topic: Last few days, technical fault with channel, disney plus etc works.
Locked
This message was authored by: Stevo1070
Re: Last few days, technical fault with channel, disney plus etc works.
I agree, there should be some form of compensation. I'm so close to sending it back as not being fit for purpose.
But they don't make getting in contact with anyone very easy.
This message was authored by: Joolz1967
Sky glass not will not load
Firstly I am not the most technical person and have slightly disability with use of hands so please be patient.....this is my 3rd year of owning sky glass and up to now everything has been fine....however recently when turning my tv on first thing it will either not play either live tv or app function.....or will do for a short period then screen goes blank and only sound remains....if I back out....I  the background a random dialogue plays few a few seconds from something I haven't even watched.....it's driving me crazy each morning!
Re: Sky glass not will not load
@Joolz1967 It's an issue a few of us are having with both Gen TV's. Sky are apparently aware of it but we need to wait for a fix.
Some of us have found that going through a factory reset with Sky will clear the issue for a longer period than the normal 'soft' reset will. Sky do advise to go through it with them in case of problems re-setting the TV back up.
 It's not a permanent fix, merely papers over the cracks.
Have you asked? I think it's highly unlikely that Sky will volunteer anything, not least because not all Glass TVs have this problem
@Joolz1967
Have moved your posting into this ongoing issue thread.
Read this thread and the answered post from Sky on the issue.
Sky are investigating and we as Superusers are keeping them aware of many others having the issue.
This message was authored by: suchfun75
sky glass
problems with sky glass watching channels  as screen tells me is loading. then, technical problems. Netflix, prime, you tube all work fine. after watching any of these or resetting tv then it works. but surely shouldn't have to do this everytime?
called sky and put through to 4 different advisors so far .
This message was authored by: Jporch316
Re: sky glass
@suchfun75
There s a large thread with some users having similar issues .... currently under investigation
@lettice please can you merge
@suchfun75
As above
This message was authored by: Rob89
TV glitch
Does anyone else's TV just glitch halfway through a program/film where the only solution is to unplug the TV then plug it back in again??
Avatar for wsimm
Level 3 icon
This message was authored by: wsimm
Update from me:
I've used my Sky Protect insurance which covers software failures and there will be a replacement glass arriving saturday (albeit Pink instead of my current green)
Lets see if this problem persists
This message was authored by: peter-marlow+1966
Re: TV glitch
Me personally  no
P c marlow
Re: TV glitch
@Rob89 Sounds like the problem many are having. Sky are aware. We have to wait for a fix.
There is a large thread about this situation:
https://helpforum.sky.com/t5/Sky-Glass-Live/Last-few-days-technical-fault-with-channel-disney-plus-e...
@wsimm I hope it does but I have my doubts with it being a software/firmware issue and not a faulty unit problem. Fingers crossed for you.
@Rob89
This message was authored by: Chloe-W22
Posted by a Sky employee
Good morning all,
Thank you for your patience as our support teams continue to investigate this issue. To gain a broader understanding and examine individual disruptions and stream performance, we're looking for more customer examples.
I've put together a Microsoft Form where I ask for a few minutes of your time to fill out the following:
Your Sky Community Username
The exact On Screen Message
Your Sky Glass MAC Address (ethernet)?
Exact dates and timesof this OSM appearing
Your broadband provider
Link to form: [closed]
Your responses will help our support teams continue their investigation. We truly appreciate your help!
I'll be marking this post as the answer to the thread so more people can see the latest update.
Chloe-W22
Sky Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
Locked
Answered - Go to Answer
