Discussion topic: Last few days, technical fault with channel, disney plus etc works.
Message posted on 28 Apr 2025 06:28 AM
Re: Sky Glass - Cannot watch anything
You will need to contact sky about this issue, especially as you have done a factory reset, as you will probably have now removed you account details from the tv and you will now need help to get it back, factory resets should only be done when talking to an advisor from sky as this can cause more problems than it solves
Message posted on 28 Apr 2025 09:41 AM
Hi Mike,
Thank you for your reply.
I did all the advised service checks and it said everything was running as it should but we could not get any channels at all.
Everything worked on my TV upstairs via the puck which would indicate it's an issue with the glass TV. However, I will also try what you have suggested.
Kind Regards,
Laura
Message posted on 28 Apr 2025 09:43 AM
Hi Peter,
If I have further problems today, I shall call sky to request further help.
Kind Regards,
Laura
Message posted on 28 Apr 2025 10:04 AM
Hi @LKJ
@what error messages are you getting ?
Message posted on 28 Apr 2025 10:05 AM
Hi,
There are no error messages, just every channel I try and view it says "waiting for programme to load".
Kind Regards,
Laura
Message posted on 28 Apr 2025 10:07 AM
Re: Sky Glass TV constantly 'waiting for programme to load', each time channel is changed
Sounds like the same issue many users are experiencing on the thread below
@lettice please can you merge with the main thread
Message posted on 28 Apr 2025 10:08 AM
Sounds like you are experiencing the same issues as many users in the thread below which is under investigation
@lettice please merge with main thread
Message posted on 28 Apr 2025 10:10 AM
Done
As mentioned above, have moved your post into this similar ongoing thread.
Read the thread and the answered post from Sky for the latest response on the issue.
Message posted on 28 Apr 2025 10:13 AM
Done
Message posted on 28 Apr 2025 10:18 AM
@LKJ Seems Sky are having issues themselves at the moment. The call centres are closed until they are resolved.
Message posted on 28 Apr 2025 10:33 AM
Thank you. I will follow your link later.
Kind Regards,
Laura
Message posted on 28 Apr 2025 10:37 AM
Re: Last few days, technical fault with channel, disney plus etc works.
Hi Kev,
Fingers Crossed.
Kind Regards,
Laura
Message posted on 28 Apr 2025 04:04 PM
Re: Tv programs not loading
I'm having the same problem. I called Sky who tell me the problem is with them and that they're trying to find a fix, but haven't yet and couldn't give a time scale! They say they'd inform us when they are able to roll the fix out. It's worth calling them to add yourself to what is starting to sound like a very long list of frustrated customers.
Message posted on 28 Apr 2025 04:51 PM
Have moved your post into this similar ongoing thread.
Seems you are aware though of the ongoing issue from your call to Sky.
Message posted on 28 Apr 2025 04:55 PM
I have just come of the phone to Sky explaining my issue to be told by an advisor that the system has told him I need to replace my tv and that I will have to pay for it £624. What on earth is going on here, this is absolutely disgusting.
Has anyone else been told this?
