Discussion topic: Keep getting technical fault
Message posted on 17 Jun 2024 07:02 PM
Message posted on 17 Jun 2024 07:32 PM
Re: Keep getting technical fault
@Gary112 Have you tried rebooting your device by powering off and removing the plug from the wall for a few minutes?
“Trying to help improve sky glass”
Message posted on 17 Jun 2024 07:38 PM
Yes done that still get the same issue.
Message posted on 17 Jun 2024 07:45 PM
@Gary112 what sort of connection do you believe is fine?
Message posted on 17 Jun 2024 07:58 PM
Broadband etc
Message posted on 17 Jun 2024 09:48 PM
Have you tried switching the connectoin from Wifi to ethernet (or vice versa depending on your setup). If switching to ethernet, you need to disable the Wifi from the Network settings and should then do a reboot.
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
Message posted on 18 Jun 2024 06:54 AM - last edited: 18 Jun 2024 06:56 AM
@Gary112 Can you access the Netflix app and run its content on your Glass TV?
Message posted on 18 Jun 2024 07:09 AM
Yeah, Netflix works fine. It just buffers a bit more. It seems to be happening more when the football is on.
Message posted on 18 Jun 2024 07:17 AM
@Gary112 launch Netflix app scroll to get help and then scroll to check network and see what speeds your getting
Message posted on 18 Jun 2024 07:22 AM
Message posted on 18 Jun 2024 09:04 PM
Message posted on 18 Jun 2024 09:08 PM
@Elisa93 have you done a reboot?
1. Go to Settings
3. Press Select
5. Press Select
7. Press Select.
Message posted on 18 Jun 2024 09:12 PM
Yes, I have rebooted the device and it's still not working
