Discussion topic: ITV1 not showing listings?
This message was authored by Starkitten This message was authored by: Starkitten
Anyone else having issues with ITV1? It isn't showing any listings on TV Guide until 8pm Sunday and makes me put my PIN before letting me watch the channel.
I have turned it off completely twice and still not fixed, it's been like this since midday Saturday.
This message was authored by m23439 This message was authored by: m23439
ITV1HD
This morning I noticed that ITV1HD in the TV Guide is blank and when I select it it tells me that it requires my PIN. When entering the PIN it plays the current programme, but the programme information is for playing Ant and Dec's Limitless win. When pressing "Select" within the programme and I scroll through the next programmes, it's showing last night's ITV1 programmes after Ant and Dec?
I've factory reset the puck but no change!
Any thoughts?
Re: ITV1 not showing listings?
Exactly same here. When I put my PIN in the programme plays, but programme info tells me I'm watching Ant and Dec, when it's Alan Titchmarsh. Haha??! !
This message was authored by Blarmhor+Bill This message was authored by: Blarmhor+Bill
ITV not showing in sky glass to guide
Not itv1 showing on sky glass tv guide. Seems to to stuck at 9pm last night
This message was authored by Fothergill1 This message was authored by: Fothergill1
@Starkitten Yes, I am getting this as well since late yesterday evening.  I rebooted my puck in case there was a software glitch at my end but this made no difference. At least when you enter the PIN it takes you to the current ITV programme.  Like @m23439 it shows I am watching Ant & Dec.
If it is concerning you then you might want to report the fault to Viewer Relations at ViewerR@Sky.uk so that they can investigate.
If my post has solved your issue please mark as an "Answer"
This message was authored by peter-marlow+1966 This message was authored by: peter-marlow+1966
No problems  on my sky glass  tv  guide with  itv gone all the way through  to next  Sunday
This message was authored by lettice This message was authored by: lettice
Ditto
Not seeing this problem on either of my Sky Stream pucks.
Can pan through Tv guide fine to next Sunday.
Think it might be best for those seeing the problem to alert Sky Viewer relations team by email to report it;
ViewerR@sky.uk
@lettice TBH it's not bothering me but it seems to be effecting some people.  I have attached 2 photos (maybe you can approve them). One shows the what's on now rail indicating Ant & Dec are now on TV and the other showns the blank line on the TV guide.
I'm sure it will sort itself out shortly.
This message was authored by Nikkimcm87 This message was authored by: Nikkimcm87
I am having this same issue, it's stuck on antibiotics and Dec's show last night and I need to put my pin in its been all day now and it's getting frustrating.
Sorted itself out for about 10 mins earlier this afternoon but now back to blank Guide. Frustrating as no way of knowing what's actually on the channel!
This message was authored by Speedy9 This message was authored by: Speedy9
I'm having the same issue,  been showing Ant and Dec all day on the listing and have to enter my PIN to watch the channel. Reset the puck but no joy.
@m23439  Iv'e been out for the evening and have just got back.  Looking at ITV appears to be back to normal (at the moment at least).
