Discussion topic: I'm looking for help to fix my TV
Message posted on
19 Mar 2024
12:19 PM
- last edited:
19 Mar 2024
01:07 PM
by
KevNewMedia
I need someone to phone me or am. It paying for that tv it's broke
Moderator note: subject of thread updated to better reflect the conversation
Message posted on 19 Mar 2024 12:23 PM
Re: Anderson
@Emmaanderson90 wrote:I need someone to phone me or am. It paying for that tv it's broke
No one from Sky will phone you. You need to contact Sky if there is an issue with your Glass TV.
Was it broken on arrival? Did you break it?
Message posted on 19 Mar 2024 12:24 PM
Re: Anderson
@Emmaanderson90 No one will or can call you, this is a customer helps customer forum, you need to call Sky if your Glass TV is faulty
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Message posted on 19 Mar 2024 01:17 PM
Re: Anderson
No I never broke it wen I got it it kept cutting off and going all fizzy making big loud noise and now it's like has water damage but no water be side it it was on the wall I took it down last night and lefted it off still the same now
