Discussion topic: How do l access channels like sky atlantic and sky original on sky glass
Message posted on 24 Dec 2023 10:30 PM
How do l access channels like sky Atlantic and sky originals on sky glass
Message posted on 24 Dec 2023 11:28 PM
Re: How do l access channels like sky atlantic and sky original on sky glass
The live channels via the TV Guide, pressing the traditional channel number in via the remote or pressing the voice search and saying "Sky Atlantic".
All the on-demand content is available in a range of places. The system is designed for voice searching specific shows really rather than displaying the catalog of shows that was the norm in Sky Q and Sky +. You can go to the TV Show section on the second rail and it will then take you to the Tv Shows page and if you scroll down quite far it allows you to select the on-demand content channel as you would do on the traditional Sky platform.
