3
This discussion topic has been answered Discussion topic: How do I customise home screen on sky glass
This message was authored by: VanessaKS1
Hi
I have a Sky Glass and all the icons have been rearranged. I want to know if there is a way to change/customise it.
I specifically want to move Outputs to the top of the screen. Is this possible?
Re: How do I customise home screen on sky glass
No: historically Sky has never permitted such customisation.
Why not use your Sky remote with a  voice command to bring up the apps and inputs rail.
Saves from the Home Screen, having to scroll down, down.
Saying 'Apps and inputs', or even saying 'go to hdmi 2' and the like.
Avatar for VanessaKS1
Thank you, that's helpful. I will try doing this instead of scrolling down and down again and again.
