Discussion topic: How do I change from sky q to sky stream and can I get multi room on stream and how much extra is it
Message posted on 13 May 2024 08:06 PM
Message posted on 13 May 2024 08:12 PM - last edited: 13 May 2024 08:16 PM
Re: How do I change from sky q to sky stream and can I get multi room on stream and how much extra i
Hi @Diddymac72
You will need to call Sky if it's not allowing you to do it online. You can have up to six pucks, you need to take out whole home subscription which is £12 on top of your chosen sky subscription. https://www.sky.com/help/articles/watching-sky-in-different-rooms-sky-glass
Remember that each puck connects to the internet and requires 25Mbps for HD and 30Mbps for UHD for each puck. So you need to ensure your broadband connection can handle the bandwidth, as content is delivered via internet and not satellite.
Also note the channel line up is different than Q. See: https://www.sky.com/help/articles/tv-channel-list-sky-glass
Also you cannot record. It cloud records some content and other content is playback via the relevant broadcasters app. https://www.sky.com/help/articles/your-playlist-and-tv-guide-sky-glass
MikeAlanR
55" Gen 2 Sky Glass atlantic blue, 65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Sky SoundBox. Former Sky Q, Sky+ HD and Sky+ customer.
Message posted on 13 May 2024 08:39 PM
@mikealanr wrote:Hi @Diddymac72
MikeAlanR
In addition to the great advice offered by @mikealanr its worth noting that when ordering a sky stream puck there is a one off £40 activation fee per puck which cobers things like (delivery, lifegime warranty of puck etc). Usually when ordering multiple pucks with Whole Home they will waive the activation fee on one puck.
