Discussion topic: Hdmi problems
This message was authored by wightred This message was authored by: wightred
Hdmi problems
Screen keeps going blank every few seconds, when I try to watch laptop through hdmi ports. Have tried different cables, still the same problem. Any thoughts?
This message was authored by mikealanr This message was authored by: mikealanr
Re: Hdmi problems
Hi @wightred
You need to make sure that the cables are rated for HDMI 2.1. If still having issues you can try plugging it into HDMI Port 2 and turning on older device compatibility (Settings > connected devices > HDMI inputs > older device compatibility).
You also need to make sure that your laptop is outputting a refresh rate Glass can handle (Glass only 60Hz).
MikeAlanR
65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Former Sky Q, Sky+ HD and Sky+ customer.
wightred
Re: Hdmi problems
Thanks Mike. Did the hdmi 2 settings. Still didn't work. Will check the refresh rate on my laptop. Cheers.
