Discussion topic: Glass sound on in standby.
Message posted on 11 Feb 2024 04:12 PM
2 or 3 times now I've walked in the room and the Sky Glass starts playing sound, TV is still in Standby! No picture. I've turned off the motion sensors only got mic switched on. Any ideas?
Message posted on 11 Feb 2024 05:49 PM
Re: Glass sound on in standby.
Have you tried pulling the plug for 10 minutes
Message posted on 12 Feb 2024 07:44 AM
Hi
yes I've had numerous issues. Not turning on at all, freezing. So I've switched off at the mains several times. This sound issue is the latest thing. ☹️
Message posted on 01 Feb 2025 02:37 PM
I was just about to post the same thing i thought I was going crazy 🤪
Message posted on 01 Feb 2025 03:11 PM
There was a bug a while ago where if you put your TV into standby with out quitting certain apps first (4OD / All4 particularly) it would continue to play sound.
Is this happening with apps or normal channels?
MikeAlanR
