28 Apr 2023 07:27 AM
28 Apr 2023 07:30 AM - last edited: 28 Apr 2023 07:30 AM
Posted by a Superuser, not a Sky employee. Find out moreSounds like it's not receiving a consistent WiFi signal - if at all possible can you hardwire directly to the router with an ethernet cable and then turn off the WiFi in the glass / puck settings
28 Apr 2023 07:38 AM
28 Apr 2023 09:29 AM - last edited: 28 Apr 2023 09:43 AM
@Graybo23 wrote:
I'm currently using a 4Gee WiFi mini dongle from EE that is supposed to have 100 mbps speed.
4G won't deliver anything like 100Mbs in the real world: that's presumably the theoretical maximum speed of the device. You might hope for somewhere between 5Mbs and 40Mbs if you're very lucky: 5G would be much more appropriate.
Is that correct the Glass TV needs 10 mbps?
That's what the initial Sky marketing claimed for HD on Stream: we suspect at least twice as fast is more realistic. 'Average' 4G may well be inadequate.
28 Apr 2023 09:36 AM
Here's the technical bit. Average 4G download speeds are likely to be between 8 and 10 megabits a second (Mbit/s), with possible instances of up to 40 Mbit/s.
https://business.ee.co.uk/help/network-and-coverage/4g-speed-what-you-can-expect/
