Discussion topic: Fault with Sky Glass
This message was authored by: Lisa261
Message posted on 19 Feb 2024 09:10 PM
Whilst watching TV our Sky glass TV will freeze and make a loud noise. We have to turn it all off to reset it. It is happen more often. We have had it around 2 months and has happened many times.
Find out more
Message posted on 19 Feb 2024 09:22 PM
Re: Fault with Sky Glass
@Lisa261 If you're using it over wifi try using ethernet between the hub & TV, turnng wifi off on the TV as this sounds like a poor wifi signal.
