Discussion topic: Connecting to Sky Glass using an ethernet cable doesn’t seem to be that much better than over WiFi
Message posted on 15 Jul 2024 12:17 PM
Re: Connecting to Sky Glass using an ethernet cable doesn’t seem to be that much better than over Wi
Thanks. Both devices are on the same ring main and the wiring on that ring main is not that old.
65" Sky Glass in Anthracite & 145 Mbps Ultrafast Broadband
Message posted on 27 Apr 2025 10:13 AM
Hi,
interesting thread.
i have 500mb fibre and get about 200mb on Wi-Fi on Sky Glass Netflix but on Ethernet I only get 55mb.
Ethernet seems to restrict Sky Glass. Not sure why
router right next to TV so having it on Ethernet seems to be the right thing to do.
Having it on Ethernet does slow it down when fast forwarding a programme.
Message posted on 27 Apr 2025 10:46 AM
@Popsy3 wrote:Hi,
interesting thread.
Ethernet seems to restrict Sky Glass. Not sure whyrouter right next to TV so having it on Ethernet seems to be the right thing to do.
Ethernet port is restricted to a maximum 100mbs
if you are that close to the router I would run off wifi .......
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
Message posted on 27 Apr 2025 10:53 AM
Hi @Popsy3 The reason you are getting much lower speeds on Ethernet is that the Glass & pucks only have a 10/100 Ethernet port but this is more than sufficient.
I have 500mbps incoming from my ISP which generally gives me 375mbps on wi-fi at my Stream puck or 85mbps via Ethernet (tested via Netflix). TBH I don't really notice any difference between wi-fi and Ethernet but as my apartment is hardwired for Ethernet to the lounge and bedroom I may as well use it.
If my post has solved your issue please mark as an "Answer"
Message posted on 27 Apr 2025 11:14 AM - last edited: 27 Apr 2025 11:35 AM
It is, by having a 100baseT chipset on the mainboard rather than gigabit, but that's still about three times the maximum data rate required for UHD with HDR and more importantly isn't prone to the fluctuations inherent to WiFi.
Message posted on 27 Apr 2025 11:21 AM
Thanks for the info everyone. 👍
I guessed it might be something like that
