Discussion topic: Connecting sky soundbox to sky glass
Message posted on 26 Apr 2024 01:24 PM
Anyone know of a way to connect sky soundbox to the sky glass please
Message posted on 26 Apr 2024 01:51 PM
Re: Connecting sky soundbox to sky glass
There is no easy way to do so: Glass doesn't have optical audio output and Sky didn't see fit to provision their (now antique) Soundbox with ARC compatibility (a likely significant reason for its failure as a product)
I think you would need to attach an ARC or eARC audio extractor to HDMI #2 on the Glass set, and then use that to output optical audio to the Soundbox.
Message posted on 27 Apr 2024 01:54 PM
If it's the Sky Divialet box( quite old now but still , in my opinion, very good for certain audio outputs it's quite simple. Set the divialet soundbox to Bluetooth then on sky glass settings-connected devices- Bluetooth devices- add new device.
