6
This discussion topic has been answered Discussion topic: Connecting box to TV
This message was authored by: David445
Where do cables from the Sky box attach to my TV?
This message was authored by: SKY1992bf Answer
Re: Connecting box to TV
@David445  other than the power cable there  is only one other cable which goes into the hdmi port on your tv
Avatar for David445
Level 0 icon
Sky Stream that is
Into one of the HDMI sockets on your TV.
Avatar for David445
Level 0 icon
OK I will try to identify what that is
Avatar for David445
Level 0 icon
HDMI port I will look for what that is
The little sockets on your TV should hopefully be labelled so it should be clear which sockets are the HDMI ones.
